I have a legacy machine using a E7500 Core 2 Duo. I did an intel burn test which put it under full load and it went as high as 100 Degrees celcius which is the TJ Max.
I put it under load with heaven benchmark and it ran at 80 degrees celcius (60% load).
When Idle it is between 30 and 44 degrees celcius.
The idle temps seem ok but the load temps are a bit concerning after reviewing some posts on others sites. I used RealTemp to assess the temperatures.
Are these temperatures too high? What can I do about it?
It is an E7500 but the bios must be old as it is only running it at 2.2 Ghz so that might have something to do with it. Stock cooler, thermal paste recently added apparently.
