Core i5-2400 idle/load temps
bsullivan1983
162
Idle temp running at ~37*C. Under load (Prime95) I hit 80-81*C in about a minute. Using stock fan/sink. They are installed correctly. Cooler Master HAF 922 case. I hit a max of 70*C playing Crysis 2 on Hardcore. Does Prime95 really just hate that CPU? Should I be worried? I understand I'll notice a difference rolling with an aftermarket fan/sink but I'd rather not have to deal with removing everything again and re-tinting, etc.
If you want to prolong the lifetime of the CPU, buy an aftermarket CPU cooler(air/liquid), its a good investment. High temperatures is the number one enemy of any electronic chips specially CPU. Warning don't do that again running Prime95 with stock heat sink a no no.
DEAR ALL i need yours help i have also intel core i5-2400 its shows in bios CPU Temp 52 C. but when i check in Asus AI suite CPU temp shows 42C.Please anyone can tell me which one is right Temp?? and what is idel temp for this processor my room Temp is 32C.
@Ali Omer
Once you are booted to Win7, if you have C1E enabled in BIOS and/or Win7 set to "Balanced" in Control Panel/Power Options, your processor will drop to lower frequency when idle. However, when you are still in BIOS that hasn't taken place yet. Therefore, your CPU will be at full speed/frequency. That is why the temp reads higher in BIOS than in Win7.
But 52C in BIOS and 42C in Win7 at idle is quite a bit warmer than normal. Check that the system is clean of dirt and dust. And check that the cooler is properly attached to the motherboard. Sometimes those push-pin feet don't open properly beneath the MB. The cooler might not be making good solid contact with the CPU.
Thanks for reply clutchc ..... can u tell me which one is best liquid cooler for this CPU???and i have a question i play battlefield 3 at ultra setting my CPU Temp goes to 65 c. according to the ASUS AI suet recorder is it right temp or not? that time room temp was 35 C. i have install Intel socket fan.....
I've never used a liquid cooler, so I'm probably not the best person to ask about that. But I have heard others state that unless you opt for a double radiator cooler, it probably won't be much better than a good air cooler.
