[SOLVED] Core i7 3770k not working on chinese motherboard Machinist B75 Pro U5
I have a chinese motherboard Machinist B75 Pro U5. According to the manual (very hard to find by the way, didn't comes in the box) "Supports Intel Core i3/i5/i7 2th or 3th generation, Xeon E3 v2, Pentium and Celeron series processors"
Now is working fine with a i5 3470s CPU. For gaming it works really good actually.
I just got a i7 3770k CPU and i have installed it, but here comes the problem. 1 second after turn the PC on, 4 beeps can be heard: no video, no boot, no BIOS.
I thought may be the CPU is damaged or dead, so i put it in another old hp office class computer (HP Compaq Pro 4300, the one where i have removed the current i5 3470s CPU in the first place) with the same socket (LGA 1155). For my surprise, the i7 3770k CPU works fine in this junk. So we can discard the CPU as a problem.
Working Around:
  1. According to UserBenchmark and cpu-upgrade websites, i7 3770k is compatible with this motherboard
  2. According to Intel Ark, i7 3770k's main differences with i5 3470s are: Total Threads (8 vs 4), base frequency (3.50 vs 2.90 GHz), cache size (8 vs 6 MB) and power consumption (77 vs 65 watts). The last one makes me wonder if this can be the issue.
  3. The "official" Machinist website, says it works with the i7 3770k.
  4. If i put back the i5 3470s CPU into the motherboard, starts with 4 beeps and boot with no problem... after restart, no beeps can be heard again. It seems like it use this beeps as a warning in case some hardware changes.
  5. I can't find any "beeps meaning" table or documentation in internet nor the motherboard manual.
Current Setup:
  • Machinist B75 Pro U5 Motherboard
  • 700w Power Suppy
  • Nvidia RTX 2060 GPU
  • 1 M.2 NGFF, 1 SSD and 2 HDD Units
  • 2 x 8GB Fury HyperX 1866mhz DDR3 RAM
Any ideas about why i7 3770k CPU does not works in this motherboard?
You should contact support for the motherboard maker if you don't see any BIOS updates for your motherboard. The issue you've stated is usually seen on boards when they don't have the right BIOS version.
700w Power Suppy
700W is the advertised wattage of the unit. What is the make and model of the PSU in your build? How old is the PSU?
In case you also have a question as to why your ram doesn't go to DDR-1866MHz, it's due to the chipset. The highest speeds the ram will go is DDR3-1600Mhz.
700w Power Suppy
Hi, thanks for the welcome.
Unfortunately this Machinist brand is very unknown, although the motherboard is very sold on AliExpress, the support they have is only an email, so I already wrote to them, and I am waiting for a response.
PSU is 1yo approximately
Model: Vortex
Brand: Raidmax
So, turns out that after many tests i came with a solution.
The CPU i7 3770k finally worked in the Machinist B75 Pro Motherboard, but i had to replace the RAM.
For reasons unknown to me, Kingstone's Fury HyperX RAM modules are not compatible whit the i7 3770k, but with the i5 3470s, all in the same motherboard. So i had to replace them with generic Hynix RAM modules.
After that, PC started, BIOS recognized the CPU and system started normally.
Never got an answer from the "official support" by the way.
