Correlation between TDP and cpu voltage
theisrafil
Commendable
Nov 27, 2016
56
My motherboard is limited to max 95 watt tdp. ( Asrock n68c-gs fx) I'm using a fx 4100 cpu and it's 95w, if I increase the cpu voltage is there any chance it will cause damage to mobo or smt ?
I used an dual core amd with that mobo for a year at 1.4 voltage. Also my fx 4100 is at 4 ghz right now and it's been a month so I don't agree with you. It isn't that low.
