I am about to do my first fully water-cooled build, but I'm a little confused. I know about corrosion between dissimilar metals from galvanic corrosion but I quickly wanted to double check with you guys.
Will mixing Acetal Nickel, Copper and Brass be alright together? I know that aluminium is the worst for loops as it corrodes quickly.
As Acetal is just the plastic on top I'm not really worried about it, unless there's something I don't know about it. Also I have seen around that it should be alright to mix these metals I just wanted to ask to be on the safe side.
Here's a list of my parts in case you need/want to know:
CPU Block - EK Supremacy EVO Acetal + Nickel
GPU Block - EK FC970 GTX ACX Acetal + Nickel
Reservoir - XSPC Photon 270 Tube
Radiator - EK CoolStream PE 480 Quad
Pump - Alphacool D5 VPP655 Single Edition
Pump Top - Alphacool HF D5 TOP Black Acetal G1/4 V.2 2 Wahl
Tubing - Mayhem Borosilicate Glass Tubing 16mm OD
Fittings - (Undecided) I will either go for the EK HDC 1/4" 16mm or the Monsoon EV2 1/4" 16mm
Liquid - Distilled water
Dye - Mayhem Deep Red 15ml
I have all the parts except the fittings, liquid and dye, the tubing is on its way.
I would prefer to use distilled water over other liquids as I think its easier to deal with, cheap and I have read that it is the best thing to use as long as you add the inhibitors.
Also what biocides and anti-corrosion inhibitors are the best to get? Also i dont want to use a silver kill coil as being able to see it would bug the hell out of me. Keeping in mind that I'm from the UK and some US stuff is unavailable to me.
Cheers for the help
Cheers for the help
