Hey guys!
I have a Corsair Carbide 275R. And a Gigabyte RTX 2070 Super Windforce OC 3X 8G. The 275R has built in vertical GPU mount for two slot cards, but that in itself puts the card fans too close to the glass, let alone the fact that my GPU is 2.5 slot and can't even fit. I wanted to know if this
https://mdcomputers.in/cooler-master-mca-u000r-kfvk01.html
Cooler Master vertical gpu mount will work on the 275R? Because the PCIe (brackets?) have bars between them. The things with the holes that screw on to the back panel, they have metal bars between them. Probably a Corsair thing to flip their customers off by not allowing them to use third party vertical mounts. My question is, will this mount work without cutting those bars?
