Corsair 500R Fans
Jack678
12
Hi, coming towards the end of my first build powered it up for the first time. Everything was fine only that the front fans and led's weren't on. There is a molex connector not connected does that have anything to do with it? I tried connecting it with the cables i got with my psu but I didn't know where to put the 3pin adapter at the end of it. I could really use some help, thanks.
ATX 24-Pin power connector
8-pin ATX 12V power connector
2 x 4-pin CPU fan connectors
3 x 4-pin system fan connectors
1 x TPM Module connector
1 x Serial port connector
1 x Front Panel Audio connector
2 x System panel connectors
1 x Chassis Intrusion connector
1 x V-Check Points Set (7x V-Check connectors)
