Corsair 750D Optical Drive Bay Issue
ImGeil
60
As the title says, I've can't seem to pop out the odd bay slot. I pushed the button, and put so much force on it, but it just won't pop out. And the manual is too vague. Any help?
Should be the same as the 900D right? If so, open the case up and reach into the drive bay area, there are two tabs on either side holding it in, push them inward it should pop right out.
Wait, I just read your question again, do you mean the slot where the power button is with all the front I/O?
