4 4kbuildforrunescape Reputable Dec 18, 2015 19 0 4,510 Jan 18, 2016 #1 So I bought 3 AF120 fans. But I'm unable to install them! Thanks in advance!
COLGeek Cybernaut Moderator Apr 6, 2009 59,753 5,405 184,340 Jan 18, 2016 #2 What seems to be the problem? The Corsair 780t uses 2x140mm or 3x120mm front fans. Are you trying to swap the original fans out? http://www.corsair.com/en-us/graphite-series-780t-white-full-tower-pc-case http://www.corsair.com/~/media/Corsair/download-files/manuals/cases/780T_InstallGuide.pdf See page 9 of the manual. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Jan 18, 2016 #3 What's the issue? It will mount them. Fan Mount Locations Front: 😀 (x3) 120mm or (x2) 140mm Top: (x3) 120mm or (x2) 140mm Rear: (x1) 120/140mm Bottom: (x2) 120mm Upvote 0 Downvote
4 4kbuildforrunescape Reputable Dec 18, 2015 19 0 4,510 Jan 18, 2016 #4 I removed the stock fans and tried putting the 120mm fans in but it doesnt support the same screws! 🙁 I've read somewhere that others have had this issue and to fix it they had to remove the HDD cage Upvote 0 Downvote
4 4kbuildforrunescape Reputable Dec 18, 2015 19 0 4,510 Jan 19, 2016 #5 How do i know which screws i need , they are fairly large ones http://forum.corsair.com/v3/showthread.php?t=141330 Upvote 0 Downvote
