I currently have a micro ATX motherboard in an ATX case but want to shrink it down into the Air 240 and do some upgrades. My CPU is an i54670k which I believe tends to run a little hotter than most. I figured it's time to upgrade from the stock cooler but the issue is that I am looking for a quiet low profile CPU cooler(max 120mm height) since the Air 240 has open sides.
Any recommendations? (There is also fairly limited number of options where I live so feel free to suggest a couple if you can)
