right so hi tech experts....em planning on buying a Corsair 500r for my new pc build...i love every bit of the case except that ugly side panel fan....now what i was wondering is there anyway to mod the case and install a clear window instead of the fan?? if so, how? ....will it affect my component temps alot? ...ive seen some similar mods on google n someone had the side panel fan behind the HDD cages (almost on an angled fan mount?) facing their gpu....is there even an angled fan mount in the case? also will it void my warranty?...i wanna be able to change between the window panel and side fan whenever i want so em guessing using glue is probably out of the question...also how obtrusive is the side fan to light anyways?....em planning on using led strip lights in my case so if i turned off the fan leds...with the side panel fan attached and laid down the led strips inside the case and turned them on...will i be able to see the insides of my pc through the side fan and mesh? ...cuz if i will be able to...then its pointless getting a window ryt?
...i noe, alot of questions there...but someone please help me out! thks
