Corsair Carbide Series 300r VS. Cooling Master HAF 932?
The 300R windowed version is a great starting platform for any system. dual 120mm fan/radiator mounting spots in the top and front bezels, with 120mm exhaust points located on the back IO panel and on the floor of the case.
With few cable management holes, Corsair did a great job at the placement of the holes and zip tie marks which provide optimal management potential.
The Cooler master HAF 932 is also a pretty good starting case. With a LOT more space than the 300R, the HAF 932 allows for E-ATX mother boards (extended) and either top or bottom placement for PSU. With as few cable management holes as the Corsair 300R it doesn't really have a gain in cable potential..
But the HAF has HUGE airflow potential. (High Air Flow) with 200mm...
But the HAF has HUGE airflow potential. (High Air Flow) with 200mm fans included on the front top and side panels.
But I'll have to recommend something a little better.
Newegg - Phanteks Enthoo Pro
The Enthoo pro has Outstanding upgrade potential at it's price range -- offers more features than so many others.
For $100 you get the features of a $200 case for budget pricing
- Native reservoir mounts for Custom cooling loops
- PSU cover to get rid of unsightly cable
- Attractive windowed side panel
- triple 120/140 fan SLOTS in the top bezel
- great cable management holes and included ties on motherboard tray
- included hardware comes in pretty sweet case =
