Goattt :
Hi TheGameAce.
Your old 300W PSU will not work with your 970. It may work on idle but the second you utilize the GPU, the wattage supplied will not be enough to sustain the system and could cause further complications.
The 500W PSU you have should work fine until you can find a replacement, and as other users have suggested, it is recommended that you do as the CX brand is not known to be reliable, especially since it is refurbished.
Now, onto the cables. I am unsure of what you have done exactly, so I'll try to be as broad/vague as possible.
You are going to have a number of cables come from the PSU. The main power is going to be either a 20 or 24 pin cable called an ATX connector. This normally plugs in around the middle-right side of the motherboard.
Plug the 4 pin AUX connector to the slot which is close (depends on the motherboard) of your CPU. It provides additional power voltage to the CPU.
You will also have 6 or 8 pin connectors. These look similar to the AUX CPU connectors, but these plug directly into the side of your 970 Video card, depending on what is required by the GPU (some require double 6-pins, some double 8-pins).
Next you will have Sata power connectors. These provide power into your drives, whether they are Sata Hard drives or SSDs. I assume you aren't running any old IDE drives.
Other then whats listed above, you might require molex connectors that provide power elsewhere, often related to the case itself (such as a built in fan controller, or LEDs).
If your front connectors are plugged in, good. Otherwise, this can be the most frustrating part of plugging things in. The best advice I could give is refer to the motherboard manufacturer and just try your best. As long as you can get the power button working, the rest is somewhat irrelevant (e.g. you can get an additional USB hub for extra USB ports).
Once you've plugged the main connectors in, and you're sure they are plugged into the right area (Pay particular attention to the 4pin CPU plug and 6-8 pin GPU plugs. Do NOT confuse these), give it a test boot and see if you can get through to your desktop. If fans start spinning but no display, check the connectors around the CPU and the monitor itself. If you get nothing from pressing the power button, check the 20/24 pin ATX connector and the front power connector.
If you run into any further problems let me know.
Hope this has helped.
Unfortunately I couldn't even utilize the CX500M. Apparently the idiots that refurbished it missed replacing several pins, so I had to go back to the 300W and just go back to the default Radeon 5450 graphics installed.
I ordered the PSU that Rogue linked me to already, so hopefully I'll have it by Tuesday, Wednesday at the latest.
Will I be able to OC my GTX at all with the extra 50 watts too?
@Rocket. Well, I guess I learn something new with computers every day. At first I thought all power supplies were relatively the same, minus the ones with the bronze, silver, gold, etc certifications. Then I realized there are different types such as ATX, and now I understand quite a bit more. I'll also know now to stay away from refurbished. Talked to a friend who does this stuff for a living, and he told me that too. Guess I shouldn't have been so hasty a week ago to not bother researching, and just order that PSU.
And don't worry; The GTX is brand new.
I'm actually only gonna be using the power supply for a few months until I can earn enough extra money to do a full custom build, which will need a 1000 watt PSU to run an FX-9590. Hence the reason I'm trying to keep costs low on this PSU, since it's just to run my GTX.
I'm just now a bit worried about the computer... I think I screwed something up when reinstalling the 300W. Now when the computer starts up, it does several beeps, and goes to some sort of bios screen asking me how to start up, showing F1 to run default values, and a bunch of other crap.
This also caused the time on the computer to reset to January 1st, 2010, and made all the drivers for my mouse, keyboard, etc, reinstall automatically, and messed with Firefox.
I will know now though, to stay away from the CX series from Corsair, and never buy refurbished, so thanks for teaching me that.
Any extra help (like the new issue I'm having, or just advice about what to look for) would be appreciated
