Corsair CX600 doesn't have correct 4 pin connector for CPU power connector
CarterWestlund
Commendable
Dec 27, 2016
I can't seem to find a cord from my Corsair CX600 power supply to connect to the 4 pin CPU power connecter on the motherboard, and my computer keeps turning on for a split second and turning off. I feel like it's the CPU power connector on the motherboard that is causing this problem. Do I need a new power supply or is there any way to fix this.
it is a 4+4 cable.
Look closely, one of your 8 pin cables is actually 2 4 pins stuck together, they will come apart, and then you just use half of it.
Thank you! That worked perfectly! Now I have another problem. When i try to get my monitor too hook up to my 1070 I don't see the same type of cords. Do I need to get new cords or will 1 HDMI cord work?
