corsair fan difrence
Marc7175
48
my question is, is this fan the same at the other 1 fan: Corsair Air Series SP120 High Performance Edition High Static Pressure
2 fan: orsair Air Series SP120 High Performance Edition
is there any difrence, theyre gonna go in the front of my fractal design refine r4, but which one to chose?
There are two types of fans, one series for Static-Pressure (SP120, SP140 ...) (Good for Radiators and CPU-Coolers, or as Case Fans if a lot of stuff is in front of them, for example HDD-Cages) and one line for Open Air Flow(AF120, AF140, ...) (The normal Case Fans). You should choose the right fans for the right places.
didnt i say they were the same fan, they are both sp 120, but the 1 one is a High Performance Edition High Static Pressure, while the 2 fan is just a static presure performance edition?
Oh ok, as far as i know Corsair has only two different SP Fans, the normal high performance, high static pressure and the quiet edition. So I think both of the Fans you named are the same. But You could always check if the Part-No. of both are the same, if the store shows it.
