corsair h100i 35c idle 55c max load
OsirisTheVirus
Hi, I am pretty new when it comes down to liquid cooling. My average temperatures on idle range from 35-45 degrees, after installing my H100i and playing around with corsair link software I decided to get prime 95 for checking load temperatures 15 min on basic blend test my max temperatures I got were 55c. Before installing my CPU cooler I ran prime on the stock cooler it got to 70c before 5min I had to shut it off because I didn't wanna cook my cpu 😛 Overall a huge difference in cooling performance, I was wondering if these temps are normal for liquid cooling or should they be better? (heard stories of 25c) also one cores always seems to be cooler by 10c not sure if the sensor is off :/
http://imgur.com/CD9yNgP cpu temps
i7 2600 cpu
