I just got an h100i v2, expecting better cooling than my super loud old air cooler. Installing it sucked, cause it took me forever to figure out that my old asus motherboard is thinner than other ones and I had to use a different backplate, but i eventually got it installed. I put it on with only the pre-applied thermal paste and a normal amount of pressure. When I ran intelburntest to check temps, they were exactly the same as with the air cooler, around 80 degrees. I was disappointed by this, but still happy because my computer is much quieter, but when I installed corsair link I saw that even when cpu temps were really high, the "h100i v2" sensor never broke 30 degrees, and when i put my hand over the radiator, there was almost no heat coming out.
Ambient temps 20 degrees celsius or lower
Running an i7-920 (ancient I know but it does what I need it to with a light overclock at stock voltage) on an asus p6t
