This is my second H105. Every 10 minutes I can hear the water flowing, it sounds like someone shooting a water gun. My first one did the same, I RMA'd it and noting changed with the new one. I tried out laying the case on its side for a while, but didn't fix it.
Did I get two faulty units or is it normal? Also the pump makes a buzzing sound, but it doesn't bother me because I cannot hear it outside the case.
Btw there are no leaks.
Anyone has the same problem?
Thank you.
Thank you.
