D dickson77 Reputable Jul 1, 2014 3 0 4,510 Jul 1, 2014 #1 I cant seem to get my Corsair H110 CPU Cooler to fit on my , Gigabyte GA-Z97X-Gaming GT Motherboard the bracket won't line up on the back , Can I buy a bracket to suit this motherboard?
Solution I I i7Baby Jul 1, 2014 Phone Corsair. They'll help. I think they have crappy instructions for their coolers though. This is about the 5th problem this week that the instructions should've been enough.
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 1, 2014 #2 It should come with one to suit the lga1150 socket. The spec says - Compatible with Intel 1150, 1155, 1156, 1366 and 2011 as well as AMD Sockets FM1, AM3, AM3+, AM2 and AM2+. Check your instructions. Upvote 0 Downvote
D dickson77 Reputable Jul 1, 2014 3 0 4,510 Jul 1, 2014 #3 Hello thanks for the reply, I know it says, it fits 1150 but when I line the bracket up on the back it won't line up with the screws Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 1, 2014 Solution #4 Phone Corsair. They'll help. I think they have crappy instructions for their coolers though. This is about the 5th problem this week that the instructions should've been enough. Upvote 0 Downvote Solution
D dickson77 Reputable Jul 1, 2014 3 0 4,510 Jul 1, 2014 #5 Kk thanks ill try that tomorrow. But I had no problem with setting it up on a 1155 motherboard . Hopfully it fits Upvote 0 Downvote
