K Kayo26 Feb 18, 2019 3 0 10 Feb 18, 2019 #1 Does it matter if I oriented the CPU water block sideways? (Corsair logo is on its side instead of upright) The reason I did this was because i felt like there would be too much tug on the tubes if i mounted the cpu block upright.
Solution Karadjgne Feb 18, 2019 Doesn't make any difference at all. You can mount the pump upside down, sideways, slant ways, doesn't matter.
Karadjgne Titan Ambassador Dec 26, 2012 30,759 4,553 142,790 Feb 18, 2019 Solution #2 Doesn't make any difference at all. You can mount the pump upside down, sideways, slant ways, doesn't matter. Upvote 0 Downvote Solution
