Question corsair h150i pro rgb High temps I7 7700k
Mar 3, 2019
HI
I recently installed the corsair h150i pro rgb in a push/pull config and did a full system rebuild into an NZXT H700,
I7 7700k Clocked at 4.8ghz @ 1.3v
100% load 94-96 degrees Celsius
Ambient Temp = 31 degrees Celsius
Case Temp = 48 degrees Celsius
Liquid Temp = 33-36 degrees Celsius
Aftermarket thermal past used(best performing past i could find at my local PC shop)
I7 7700k Clocked at 4.5ghz
100% load 78-82 degrees Celsius
I am going bold here, scratching my head to figure out why the Temps are so high. as my antec 240 rad performed better than the H150I pro
Any suggestions?
