Corsair H60 CPU cooler
The 1150 and 1155 socket are the same physical socket layout, so anything that fits one will fit the other. Good air cooling will match and beat AIOs with 120mm radiators. If you want to feel the benefits of water cooling in a thermal sense you have to go with 240mm or 280mm radiators on the CPU. Generally 120mm AIO perform on par with mid-performance air cooling.
They are good in ITX rigs that have room to mount one as they offer better cooling than most low profile air. Other than that not much benefit besides looks and getting the hot air out of the case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030 Specs tab
Block Compatibility:
Intel: LGA 1150 / LGA 1155 / LGA 1156 / LGA 1366 / LGA 2011
AMD: Socket AM2 / AM3 / FM1
While compatible, it's not a cooler I'd use.
http://www.overclockersclub.com/reviews/corsair_h60/4.htm
Loses by 4C to the Noctua DH-14 under load overclocked which in turn loses by 1-2C to the same price Phanteks PH-TC14PE
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ph-tc14pe&N=-1&isNodeId=1
