Corsair H80i V2 vs be quiet! Silent Loop 280mm vs Corsair H115i ?
dazkyl
1,036
Which one of the above coolers would you suggest for an overclocked i5 6600k @ 4.8ghz ? What's the difference in temps ?
If not , which cpu cooler would you suggest?
Thanks
I'll definetely go for the BeQuit then. Never owned a cooler from this brand. Is it any good ? Also whats the difference in temps between it and the h80i v2 ?
I'll go for the BeQuiet then. It is compatible with 6600k i5 and corsair graphite 780t case , right ?
