Corsair HX750 6pin question?
wheelzz
97
Hello readers,
I recently built a PC using a Corsair HX750 PSU. I am going to do cable management now and I need to know whether it is okay to plug both my 6pins into the blue connectors on the PSU side by side.
heres a picture of the PSU:
http://images.highspeedbackbone.net/skuimages/large/C13-2510-main01-op.jpg
Do I need to connect one on each level or is it okay to connect side by side in the blue?
So I can plug both the 8pin-6/8 connectors to whichever blue slot I want and I can connect both my sata powers to whichever i want? Like, I could have both the blues and sata power over top eachother on one side of the PSU?(blue plugged in then the other plugged in up top it and sata power plugged in with the second up top of it?) Im wondering so I can plug them all closest to the one side to get best cable management.
The Blue connector is designated for PCIE/GPU. The others is for other loads.
Its a single rail PSU. All load goes to one 12V rail so its safe.
Corsair provides a lot of cable options. Its always good to manage your cable
1)I use the Blue for PCIE/GPU
2) I separate the drives
3) I separate the fans & Coolers
