CORSAIR Hydro Series H60 Liquid CPU Cooler for i5 6600k ?
InFamous-N-
Commendable
Jul 15, 2016
8
Good day fellow members,
I have a dilemma, i have recently purchased an I5 6600k cpu and as it does not include a cpu cooler.
Thus i find myself here seeking advise , its my first build and due to me spending half my budget on the cpu alone , im trying to find the best possible solution for my build / budget.
I want a cooler that will perform well with this chosen cpu as well as be silent .
My budget is $80 which is the cost in my country for the H60.
the mobo for the build will be a msi H110m gaming ( will upgrade later on )
Another comparison to the H60 would be the DeepCool MAELSTROM 120 ( would this be as good or better?)
Thank you for your time and feedback, will be much appreciated.
http://www.coolermaster.com/cooling/cpu-air-cooler/v6gt/
165mm high, so given that the 212 series only sometimes fits the Spec-02 and Spec-03 cases, I'm pretty sure it will be too big.
Also, noise levels don't look very good for that cooler, looking at a couple of reviews:
http://www.guru3d.com/articles_pages/cooler_master_v6_gt_review,8.html
http://www.tweaktown.com/reviews/3371/cooler_master_v6_gt_cpu_cooler/index6.html
As far as price, that TweakTown review said the MSRP was $69.99 when it came out, so $50 seems a bit high for a 3yo used model.
as that item has been discontinued, it was actually $90 in my country when it got released. which is what my friend had paid.
i will check out your links and research its specs in regards to noise etc..
thanks .
