M mathiasry343 Reputable Jun 28, 2014 40 0 4,530 Apr 1, 2016 #1 so my corsair k95 made a power surge and now its stuck in BIOS or smth there is light in it but no keys work. every thing else works, but not my keyboard no matter which port i put it in
Solution jimmysmitty Apr 1, 2016 Then it looks like a surge killed it. I suggest contacting Corsair and see what they are able to do. Possibly RMA it for a replacement. http://www.corsair.com/en-us/support/warranty
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Apr 1, 2016 #2 Define what you mean by your keyboard "making a power surge". Upvote 0 Downvote
M mathiasry343 Reputable Jun 28, 2014 40 0 4,530 Apr 1, 2016 #3 turkey3_scratch : Define what you mean by your keyboard "making a power surge". Well it used too much power then disconnected and got stuck Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 595 59,140 Apr 1, 2016 #4 I don't know how it could use too much power as it is designed to draw a certain amount unless there is a short. Have you tried switching the keyboard to one of the other 3 available BIOS using the switch on the back of the keyboard (it is near the USB cable)? Upvote 0 Downvote
L lakimens Honorable Jul 20, 2013 2,877 1 13,460 Apr 1, 2016 #5 The keyboard used too much power? Is that even possible, the most it can use over the usb port is 5V and 3A(I think?) Upvote 0 Downvote
M mathiasry343 Reputable Jun 28, 2014 40 0 4,530 Apr 1, 2016 #6 jimmysmitty : I don't know how it could use too much power as it is designed to draw a certain amount unless there is a short. Have you tried switching the keyboard to one of the other 3 available BIOS using the switch on the back of the keyboard (it is near the USB cable)? i have tried everything. maybe it wasnt my keyboard which used the power but it just said something did something did Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 595 59,140 Apr 1, 2016 #7 Have you tested the K95 RGB on a different system? And made sure both cords are plugged in? Upvote 0 Downvote
M mathiasry343 Reputable Jun 28, 2014 40 0 4,530 Apr 1, 2016 #8 jimmysmitty : Have you tested the K95 RGB on a different system? And made sure both cords are plugged in? i just did and the keyboard is broKeN ;( Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 595 59,140 Apr 1, 2016 Solution #9 Then it looks like a surge killed it. I suggest contacting Corsair and see what they are able to do. Possibly RMA it for a replacement. http://www.corsair.com/en-us/support/warranty Upvote 0 Downvote Solution
M mathiasry343 Reputable Jun 28, 2014 40 0 4,530 Apr 1, 2016 #10 jimmysmitty : Then it looks like a surge killed it. I suggest contacting Corsair and see what they are able to do. Possibly RMA it for a replacement. http://www.corsair.com/en-us/support/warranty i am trying to claim warranty, thanks for helping me tho 😀 Upvote 1 Downvote
