Corsair lightning node pro and commander pro question
jinqty
36
Good day everyone! its been a while since I last posted a question here on tom's hardware.
I have a question. I recently bought a Corsair commander pro and I was thinking of buying light strips so I'd like to know if I still need to buy the lightning node pro or just the lightning expansion kit? I tried to search for an answer first but found any existing post so I hope I wasn't replicating the same question. Any advice and answer are greatly appreciated! I missed you guys! hehehehe
As long as you aren't using both Lighting Channels on the Commander Pro, you don't need the Lighting Node Pro - you're fine with the expansion kit.
The CoPro has all of the functionality of the NoPro and then some.
