Hi, im planning to connect components from the title on x370 mini itx motherboard.
Motherboard has 2 rgb headers (one 3 pin, and one 4 pin), with masterliquid i got 3 way rgb spliter in which i can connect 2 fans and pump rgb and i assume i can connect that to rgb header so i can avoid using controller hub.
Can i do the same with 2 corsair fans so i can avoid using usb2 port on motherboard or those fans have to be plugged in specifically to lighting node pro?
