Question Corsair ML120 PRO
Azfar Siddiqui
146
Hi,
sorry if this is a dumb question
i want to know about corsair ml120 pro rgb and LL 120 rgb fans hoping someone who has similiar setup can answer
if i set ml120 fans at radiator and LL120 at front will i be able to set light colors using commader pro at all of them together. the case i will be using this in is corsair 500 d SE
i am hoping that the RGB wouldnt look weird since its top mounting fans
That should all work together in theory. The commander pro built in to the case is supposed to be able to handle the 16 LED fans, so there shouldn't be any problems running 4 LED fans with it, especially since they're all individually programmable in iCue.
