Corsair OR Cooler master case ?
Cryteknologi
93
searching for some mid tower case and stuck between this two case (my budget was 520$) the first case was cooler master N400 KWN2 with side panel window , the second one was Carbide SPEC-01 , who's the one is the better case ?
corsair is a bit more expensive , dont know why seems the N400 had more advantage over the carbide SPEC-01 , the N400 had 4 USB port while carbide just 2 & n400 had more "ventilation" if im not wrong n400 can place up to 2x 240mm radiator in the top of case & in the right side panel , still need you guys to advice me on 😀
Hello, Cryteknologi.
I'l go with Carbide SPEC-01, the Corsair CASE. It looks great, you have windowed side panel, you can go with led vents. This is my opinion.
There is not a big difference between this cases...
I just bought Zalaman Z11 Neo, best case for this price in my opinion...
