F Fallout life Reputable May 13, 2015 31 0 4,530 Jun 10, 2015 #1 Need suggestions for corsair psu i should use need to be modular so i dont have clutter http://pcpartpicker.com/p/zWwtyc.
Solution Jon-Doe Jun 10, 2015 http://pcpartpicker.com/part/corsair-power-supply-cp9020081na Little more than you need but it is efficient and fully modular. Good choice going with Corsair. Hope this helps!
bignastyid Titan Moderator Jun 19, 2011 33,698 1,706 159,590 Jun 10, 2015 #2 HX, HXi, AX,AXi are the only ones I reccomend. Any reason it has to be a Corsair? Upvote 0 Downvote
yatys93 Distinguished Jun 3, 2014 826 0 19,160 Jun 10, 2015 #3 Corsair RM650 should do you fine! Upvote 0 Downvote
Jon-Doe Reputable Jun 6, 2015 139 0 4,710 Jun 10, 2015 Solution #4 http://pcpartpicker.com/part/corsair-power-supply-cp9020081na Little more than you need but it is efficient and fully modular. Good choice going with Corsair. Hope this helps! Upvote 0 Downvote Solution
