According to Corsair you cannot mix fans on the controller, but you can just buy the 3 pack of Corsair fans (ML RBG Elite with node) that comes with a hub that will run 6 Corsair fans if you decide to add more. I wouldn't get a Commander core unless you really have to since it is a lot more sensitive to issues than just a fan node.I got the Arctic fan hub when I built my pc but now I want to add more rgb and fans to it. I was going to buy the Corsair RGB controller but I cant find a straight answer on if it needs a corsair commander pro as well or if any fan hub will work.
