synphul :
Wasn't cwt who manufactures all the cx/vs/rm lines? When's the last time seasonic has had a tier3 unit? Comparing a company with a track record of weak designs over one that's been at the top of the game for well over a decade leads to doubts. When the proven track record comes out cheaper, it doesn't take a masters degree to sort that one out.
Granted it's not a complete list and the tiers are rough tiers but many based on the rec's of jg and others. Someone else's list, so it's not cherry picked either. The th psu tier list.
27 tier 1 units
14 are seasonic, 3 are cwt.
36 tier 2 units
11 seasonic, 2 cwt.
43 tier 3 units, no seasonics fell into this low of a category while 10 of them were cwt.
15 tier 4 units, barely a grade above "don't bother" populated by 4 cwt's. Again, seasonic had nothing this low quality.
You've probably seen my participation in that "TH PSU TIER LIST" thread. My opinion is that whole list is bullshit, therefore your reference to it is also bullshit. Pardon my bluntness. I tried to update it with a list of my own, but it's too much of a time suck and, quite frankly, if you have to refer to a tier list instead of a proper PSU review, you're just lazy.
Seasonic is a smaller factory that doesn't do any custom platforms. Asking them for any kind of customization of existing product is like asking someone to cut off their own penis. The good news for the consumer is consistency. The bad news for the industry is a lack of differentiation between competitor's products and you end up commoditizing your own product because you can only really compete on price. CWT has many lines of varying capability. If you have a good engineering team, you can have them build whatever you want... or you can just pick something from their existing line up (which is generally "lower tier" like VS and CX). But they've also done very good work, like Corsair's HX, Thermaltake's Toughpower Grand Platinum or Toughpower DPS Platinum and Titanium., Lepa's Platinum 1700W or the entire Enermax product line (using Enermax's own designs) for the past two or three years. I can guarantee you that none of those products come off the same like as a Corsair VS or CX.
Personally, I'm not sure where Seasonic got such a "high tier". Sure, they're consistantly good quality and almost always get good reviews, but their RMA rate certainly isn't any lower than most of the other CM's out there. For example: Corsair's AX line is still made by Seasonic... and the RMA rate is just as high on them than any of Corsair's CWT built products.
Consequential data, so I suggest taking it in with a grain of salt, but you might find this interesting:
https://translate.google.com/translate?depth=1&hl=en&ie=UTF8&prev=_t&rurl=translate.google.com.hk&sl=fr&tl=en&u=http://www.hardware.fr/articles/920-3/alimentations.html
synphul :
It's not to say cwt can't come up with something quality but lets face it, their track record speaks for themselves. Personally I wouldn't use a corsair unit if it was given to me. That's just my personal opinion, they're not reliable enough.
Based on what data? I guarantee that if you were to poll Amazon, Newegg, Scan, etc., they're not going to tell you that Corsair is RMA'd more than any other major, enthusiast brand.
synphul :
It's halfway through 2015 and the big sales pitch is 'using all japanese caps' - something quality motherboards and psu's have been doing for years. In that sense I'm glad they're finally catching up, but the ss750km was released in 2013 I think it was? I'm not hateful towards them or anything but anyone can see cwt's quality has definitely been all over the place. There's no reason for it, the cost savings isn't even there. I can't recall how many times I've seen potential system builds going with a lower tier unit likely not using all japanese caps that was cwt based and at the same price they can easily get a higher quality ss or evga (superflower) unit. I won't say it directly impacts the performance of this model psu, that would be foolish - but cwt/corsair hasn't exactly had a track record of quality/value either.
Corsair usually uses Japanese caps (look at the old VX or TX), but there was a different product manager for CS and RM and he didn't specify and AVL for caps. AX, AXi, RMi, HXi... all use Japanese caps. VS, CS and CX don't, but they compete at a lower price, entry level price point that Seasonic doesn't even try to compete in. An SS750KM is NOT in the same price range as a CX, so at least compare apples to apples.
synphul :
You mention that the software allows other features that makes it 'do more' like calculate efficiency. So if I calculate it and see how efficient it is - and it's not efficient, is there a setting to increase efficiency? That's what I mean by 'gimmicky' features. A hardware monitor can check things like cpu temp, something that can be problematic and/or resolved by a higher fan profile, something the user can alter and react to. Efficiency is hardwired into a psu, so if efficiency isn't ideal then what? It's already supposed to be tested and proven 'efficient' from the factory and through tests done on the units to confirm the specs. I can monitor voltages of any psu with programs a lot of people already use to check thermals, things like hwinfo64.
Of course you can't "adjust efficiency". I suspect you're joking... But efficiency can change with different loads. But aside from seeing your PSU's efficiency at different loads..... You have no interest in knowing how much power you're using when idle? When gaming? When benchmarking? I see that as another level of hardware enthusiast; one that likes to be educated in actual power usage/requirements of particular PC hardware and then, in turn, can educate others on precisely how much power they may need.
And you must be joking about monitoring voltages with programs like AIDA, HW Info, etc. It's a KNOWN ISSUE how inaccurate those programs are. Not because of bad programming, but because of how and where they get their data. They're not getting it from the PSU itself. I have a Skylake build down in the lab that HW Info tells me has +7.4V on the +12V. I have a DMM shoved into one of the spare PCIe cables and it's reading +12.3V. Really freakin' accurate there. And certainly no third party software is going to tell you the actual load on any of those rails, never mind total wattage used.
