I have a pre-built desktop computer running Windows 11, which I mostly use for gaming. The power supply is a Corsair RM850e, and the graphics card is an AMD Radeon RX 7900 XTX.
I frequently get `DXGI_ERROR_DEVICE_REMOVED` crashes in games, indicating that the graphics card has become temporarily inaccessible. As part of my troubleshooting, I want to check whether my graphics card is getting sufficient power from my PSU.
The graphics card has three 8-pin PCIe ports. The vendor that pre-built the computer connected it to the PSU with the following cables:
Corsair states that a pigtail cable with CORSAIR Type 4 on the PSU side can supply 300 W to a component. Is this actually true in practice, though? Is this cable setup adequate for powering my graphics card, or do I need to buy a power supply with an additional PCIe socket to phase out the pigtail, such as a Corsair HX 1000i?
Details
- A cable with an 8-pin PCIe end on the graphics card side, and an 8-pin CORSAIR Type 4 end on the PSU side, and...
- ...a pigtail cable with 2 8-pin PCIe ends on the graphics card side, and one 8-pin CORSAIR Type 4 end on the PSU side.
Details
- PSU: Corsair RM850e; 850 W; obtained when new; now 6 months old
- Disk drives: Two SSD drives (T-FORCE TM8FFW002T). Each has a capacity of 2 TB. One contains a Windows 11 installation and is about 50% full. The other contains an Ubuntu 24 installation and is about 30% full. I have a dual boot set up where I see the Ubuntu disk's GRUB bootloader on startup, and use it to select either operating system. I use Windows for games and Ubuntu for productivity. I never mount an OS's disk when using the other OS.
- CPU: AMD Ryzen 9 7950X3D 16-Core Processor, 4201 Mhz, 16 Core(s), 32 Logical Processor(s)
- RAM: Four of the following RAM stick -- 16GB DDR5 6000MHz T-Force Delta RGB -- for a total of 64 GB
- Peripherals:
- Mouse: Asus ROG Chakram
- Keyboard: Keychron K1 Max QMK/VIA Wireless Custom Mechanical Keyboard
- Monitor: LG 49WQ95C-W
- Headset: HyperX Cloud Revolver (wired)
- Network: Wireless
- Games that have crashed (all on Steam):
- Final Fantasy 7 Rebirth
- Baldur's Gate 3
- Solasta: Crown of the Magister
