corsair sp fans
noctuas are widely regarded as the "best" all around silent fans because unlike most silent pc fans they tend to move a respectable amount of air, making them acceptable (not amazing) for heatsinks and radiators too.
Of course you do pay for that quality as they are quite expensive as fans are considered. I personally have a few noctuas and i love em. So i don't think you'll go wrong with them.
scythe gentle typhoons are some of the best radiator/heatsink fans for high performance airflow. Of course they're hard to find too.
you can't really find a bad noctua, generally just grab one the size you need and you're good to go.
if you want an LED fan, the best are probably the SilentX LED fans... that said, the best LED fan is quite a far step away from a good gentle typhoon or noctua, so while they're alright, don't expect miracles.
