Corsair TX550M and EVGA GeForce GTX 1080 Ti SC
madsseitjespersen
I am building a new rig, and due to a really nice sale I convinced myself into getting the EVGA GeForce GTX 1080 Ti SC.
However I based my basic specs on using another card and I have bought the Corsair TX550M Gold rated as my PSU (Also got that for 1/3) of the price.
Now I noticed that the gpu "needs" a 600W psu. Should I return it and use more money on a bigger psu or will it work?
No plans on overclocking, specs as follows
ASUS ROG Strix B250I
Intel Core i7-7700K
HyperX Fury DDR4 2400MHz 16GB
2x SATA SSD
Fractal Node 304 mITX
Best regards
Echoing MM above, completely and totally wrong. 550w is plenty for him. The "recommendations" that Nvidia and AMD put on GPUs are based on a worst case PSU (low end poor quality).
The only thing a random shutdown under load may do is corrupt...
But why 750w that is vastly more than the system needs? Peak is as far as I can calculate 420. Wouldent 650 gold psu be more than enough with plenty of room for error?
Didn't know it can output 640W, good to know. However, you agree if it is max 550, not enough, right?
If you don't know what a PSU can output then why are saying it's not good enough? Please do your research before recommending that people spend money that they don't need to spend,
not trying to get the OP to buy a new PSU? Really?
The only thing a random shutdown under load may do is corrupt some data on your hard drive, there is no chance of damaging the GPU.
Please don't spread misinformation to our membership.
