Hi, i have problems to set my ram at 3600mhz.
This set:
- Motherboard: B450 aorus pro wifi Bios Ver. F50 AMD AGESA 1.0.0.4 B
- CPU: Ryzen7 2700 Pinnacle Ridge
- Memory: DDR4 - 16 Gb 2x8 3600 Mhz Vengeance Rgb Pro Blanco Corsai - CMW16GX4M2C3600C18
My problem is that when pc boots, restart a feew times and then puts memory clock at 2133. So i enable xmp profile 1. But clock dosent change and keep in 2133mhz.
The Ram Kit ddr is broken?
The motherboard is broken?
Is this module a waste of money for me?
The only way to work fine is manual OverClock? i neve did that before. I can learn about that. If is the only way i will do.
Please help... every is new and stock set-up.
I do not deserve this problme!.
This set:
