Hi,
Just wondering what settings i should be using because this doesn't seem right? that speed would only be 1333mhz?
Ive tried using XMP setting in bios with the correct voltage but the system just crashes.
http://www.corsair.com/en-us/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a2400c10
this is the memory im using
cpu i5 3570k (standard atm until i can fix this usually oc to 4ghz)
mb: asrock extreme6 z77
any help appreciated thanks
