corsair vs550 watts 4 pin atx ??
8 pin eps means that it supports mobo's with 8 pin cpu's that draw a lot of power like the fx - 8350. That said, that psu would work perfectly fine with your mobo. However, I wouldn't recommend it to you.
For more info about eps look here: http://www.ehow.com/facts_5761664_atx-vs_-eps-power-supply.html
And since your mobo has a 24 pin connector it means that it is an eps supported mobo. EPS means entry-level power supply standard.
I wouldn't go with that psu if I were you.
please help iam not technical
so my mother board support this power supply..or 8pin eps split into 2..4 + 4
that 1*4 pin atx 12v...can i connect to my mother board 4 pin atx
Look at that. It has 8 pins all in 1. If you need only 4, it will fit into the 4 and the other 4 will be left to the side and your pc will run absolutely fine. Please do not go with the vs series psu's. They are not good.
thanks akhil for reply but i already buyed in amazon.in and they shipped i want this power supply for my msi r9 270x 2gb cross fire. beacuse it has 6 pin x 2..
thank you akhil for help me..
Always ready to help. Enjoy.
