Could anyone help with a monitor problem?
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Its an Nec multisync 97 and I have it hooked up to 2
computers with a KVM switch. Both have the same issue.
Its been working fine but just recently the icons and
text at the top of the display are "squashed" looking.
They are normal at the bottom.
I can't find anyway to adjust.
Maybe its time for a new one?
Thanks
> Thanks
You have what is called a vertical linearity problem. If the monitor
is more than a year old, it is probably cheaper to buy a new one.
On Thu, 13 May 2004 22:21:44 GMT, mota <dave5021@hotmail.com> put
finger to keyboard and composed:
>Thanks
Vertical linearity problems in older monitors or TVs could be caused
by dried out electrolytic capacitors in the vertical deflection stage.
It's a cheap and simple repair, ... if you can do it yourself.
- Franc Zabkar
Please remove one 's' from my address when replying by email.
user@domain.invalid wrote in
news:NZUoc.53865$Ut1.1461879@bgtnsc05-news.ops.worldnet.att.net:
> monitor
Thanks for the reply....its 2 years old
Franc Zabkar <fzabkar@optussnet.com.au> wrote in
news:ak09a09c3m87pbue2lrttrk1i9i1rmjod4@4ax.com:
> - Franc Zabkar
Thanks for the reply Franc....its probably beyond me to repair.
