Does anyone know how a CPU heat sink could prevent a computer from booting?
Here are the details. I have a Gigabyte GA-MA790FX-UD4P motherboard with a Phenom II X3 710 processor, using the stock heat sink. I upgraded my BIOS to F8G (which supports the latest AMD processors), and ordered a Phenom II X6 1090T processor, but when I installed it the system wouldn't boot. I don't have a speaker in my system, but the disk activity light went into a repeated pattern of four blinks, and the display was never initialized so I didn't get any error message.
I figured that the processor was defective, so I returned it under warranty. When I tried the replacement processor, I got the same error. I then reinstalled my X3 processor, but using the heat sink that came with the X6 processor, and got the same error in that case as well. So it looks like the system won't boot with the new heat sink. The question is why. I've thought of a few possibilities, but they all seem improbable:
1) The BIOS is refusing to boot because it thinks that the CPU fan is not running. I think I've ruled this out because the fan does operate, and when I tried booting with the fan unplugged, the system shut down immediately, rather than making the disk activity light blink.
2) The CPU is overheating. There is no sign of physical damage to the heat sink, but I suppose that the heat pipes could be defective.
3) The clips for the X6 heat sink appear to place more pressure against the CPU that the heat sink for the X3 does. Perhaps this causes the motherboard to bend slightly, causing it to malfunction.
When AMD sent me the replacement processor, they included another heat sink, which I haven't tried. I'll wait until tomorrow to try it (when I'm less tired and hopefully less likly to bend a CPU pin).
