Question Couple graphics card issues.
DylBKR
61
13
535
I’ve had my Pc for around 3weeks now so it’s very fresh but have ran into some issues in relation to the GPU. It’s an ASRock 6800xt and it does exactly what it should when it’s working but I’ve had two instances one just now and another a few nights back where the GPU just turns off. All other components in the pc turn on so I go inside double check connections and push the gpu towards its socket and this solves it but this doesn’t really make any sense as a solution because everything is firmly in.
Any recommendations.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
if the PSU's been in service for a while, please include the age of the PSU apart from it's make and model.
As for your GPU, if you're having to touch the parts, reseat them and that resolves the issue, it could be a loose connection(power or PCIe slot) or you're having a grounding/static build up issue.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
My bad lemme load up a partpicker.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
