CPU 100%used !! Help !
doman
6
can anyone help me ?? My PC is getting slower and slower recently, it says that "CPU 100% used" why would this happen and how could i deal with it ?? THX
virus... go control/alt/delete and go to proccess and see what is using your cpu resources... write the name down, then end the program... then research how to get rid of it...
<font color=red><b>NF7-S/Mobile Barton 2600+
210x12.5 1.8V
1GB XMS PC3200
9500np modded to 9700np</b></font color=red><font color=green><b>
NF7-S/Unlocked Barton 2500+
200x11.5 1.76V
512MB XMS PC2700
Ti4200
What application is using all of your cpu resources... you can get hit even after a fresh install...
210x12.5 1.8V
1GB XMS PC3200
200x11.5 1.76V
512MB XMS PC2700
Ti4200
Look in task manager to see which app use the cpu. ctrl-alt-delete open it, and look in processus
-Always put the blame on you first, then on the hardware !!!
I found these two task using up 20-60 of CPU, they are windns32.exe & services.exe, then what can i do ?? THX !!!!
i'm using win 2000. i have re-installed the win 2000 however the warning of cpu 100% used still occured (but the frequency is not as often as before). i have checked the task manager and found that windns32.exe & services.exe occupied most of the cpu. what can i do? help!
I'm pretty sure that windns32.exe is a worm. Looks like you have a virus. Maybe try <A HREF="http:// http://housecall.trendmicro.com/ " target="_new">http:// http://housecall.trendmicro.com/ </A> or if clicky dont work cut and paste http://housecall.trendmicro.com/
Yup - It's a worm <A HREF="http://vil.nai.com/vil/content/Print100067.htm" target="_new">here</A> is some info...
Do you use any Antivirus Software? It doesn't take long to get a virus-infected e-mail these days, so even if you do a fresh install, within hours you could be infected again.
if you need some AV software you could use <A HREF="http://www.grisoft.com/us/us_dwnl_free.php" target="_new">AVG 6 free edition</A>
Some firewall software would also be a good idea, if you don't have any. Zonealarm is a free one which does the job. There may be better ones out there though.
Epox 8RDA+ rev1.1 w/ Custom NB HS
XP1700+ @205x11 (~2.26Ghz), 1.575Vcore
2x256Mb Corsair PC3200LL 2-2-2-4
Sapphire 9800Pro 420/744
Next time you will install Windows do this in the following order :
1. Install the OS WITHOUT your Lan card connected to the net
2. Install a firewall (I recommend ZoneAlarm)
3. Install Anti-Virus software (anyone you like)
3. Connect your PC to the internet
4. Update your Anti-Virus definitions files to the latest version
5. Go to www.windowsupdate.com and install ALL the security patch. You will probably have to reboot 100 times (go blame Microsoft for that)
6. Don't use OUTLOOK for your e-mail, anything else is better (I recommend Mozilla.org/ThunderBird)
7. Install ad-aware are run it once a week.
8. DON'T INSTALL CRAP (like Kazaa) and scan the files you D/L from the net.
9. And so on... But I stop there, if you do all this and want more advice, reply to this message.
Would you buy a potato powered chipset?
What's up with Outlook, I use Outlook Express whole my life and don't get any nestie worms, it is not an Outlook but those who are "looking" into the wrong things getting "stuffz".
..this is very useful and helpful place for information...
I strongly recommend <A HREF="http://www.free-av.com/" target="_new">AntiVir</A> for Virus Guardian. It is a BMW of Antivirus Software, but not as expansive😉>
There is nothing wrong with Outlook, it's just that 95% of the worms/virus are made to abuse Outlook/Windows flaws, so not running Outlook reduce the chance of getting virus/worms a lot.
If you have a firewall and a up-to-date Anti-Virus software and you are smrt enough, you will probably never get a virus through Outlook.
But, outlook don't have all the features I need and use in a e-mail client, so it's why I use Mozilla.org/Thunderbird.
