CPU and build check
Othello_G
Commendable
Mar 7, 2016
38
So I'm building a gaming PC, these are my components http://pcpartpicker.com/list/X4NnHN
I was wondering if it would be worth it to change from an i5-6500 to an i5-6600?
Also if anyone has any suggestions on parts that would be better for my build while staying in the same price range, that would be great.
i5 6600 have better performance in single core against i5 6500. Depends of you if the money/performance worth.
About your build, in general is ok, except the CPU Cooler, the stock default CPU cooler will do the job, else, you can pick the EVO 212 if you want.
