[SOLVED] Cpu and Dram led red
Jun 22, 2020
57
im "upgrading" (parts from another pc) my pc and the leds show cpu and dram red. idk what cpu or ram or motherboard is it as i cant check because theres no display . if anyone can help that would be great but idk the specs thing so i dont really expect much answers. or really that much about computers. also idk if this counts as motherboards because i think its more of a ram and cpu issue but it used to work and ive never touched the pc since so unless the cpu just bent itself
the model number of all hardware is usually labeled on the hardware
if you can´t find the numbers, take some pictures of your hardware, upload to imgur.com and post the links
