[SOLVED] cpu and motherboard combos - help please-
ripo66
22
Ok I decided to edit my question more efficiently
I'm new here and also sorry in advance for my English..
I have a number of motherboards And number of processors (attachd in the list below)
I want to assemble and build from the list 3 computers I would be happy if you could please help me with the the right and strongest combination
number one 1 will be The most powerful (cpu and motherboard)
and so on ....
2nd place
3rd place
By the way I am aware that the hardware is very old
CPU:
E7500 CORE 2 DUE
E4600 CORE 2 DUE
E2160 PENTIUM
E5400 PENTIUM
E8400 CORE 2 DUE
E5200 PENTIUM
E7400 CORE 2 DUE
E5700 PENTIUM
E2140 PENTIUM
E7200 CORE 2 DUE
Q6600 CORE 2 QUAD
E6750 CORE 2 DUE
motherboard:
INTEL DG41WV
INTEL DG41TY
INTEL DG31PR
INTEL D945GNT
INTEL DQ965GF
INTEL D945GCNL
INTEL D102GGC2
INTEL DP35DP
ASUS -P5KPL-AM
ASUS P5LD2-SE
ACER -EG31M
MSI 7346 -MS P-6-N SLI V2
GIGABYTE GA-P35-DS4
GIGABYTE GA-945GCMX-S2
GIGABYTE GA-P31-DS3L
GIGABYTE GA-G31M-S2L
GIGABYTE GA EP-43UD3L
Thanks in advance everyone
45 \ 4x is the newer one ? In what is it most expressed in performance?
And what exactly is it? L2 cache ?
And what exactly is it? base frequency ?
Yes - from those motherboards listed, one with P43 chipset is the newest one.
Newer chipset means various improvements like newer/faster USB version - USB ports work faster, newer/faster SATA version - SATA ports work faster, PCIE slots work waster, etc.
L2 cache and cpu base frequency - you know, you can google it. Right?
https://www.pcmag.com/encyclopedia/term/l2-cache
  1. Ranking list of the most powerful processors and powerful motherboards The strongest from the strongest to the weakest ..
  2. Ranking list of the newest processors and newest motherboards (in terms of their year of manufacture) from the newest year to the oldest year
  3. what combination of a powerful processor and a powerful board would you combine together?
There is only one quad core - that's the best one. Rest are two core and those you can order by base frequency.
Use ark.intel.com
https://ark.intel.com/content/www/u...500,37212,33910,40478,29739,32242,36503,29765
Motherboards you can order by chipset generations.
945,965 - the oldest, then P/G 31,35,41,43,45 - newest
(G model is with integrated graphics, P - without it).
For combinations - search cpu support list for particular motherboard. That's just exhaustive work. You'll have to do it yourself.
Hope, this helps.
HEY
SkyNetRising
what is the best 3 combination of a powerful processor and a powerful board would you combine together?
I'm aware that this is very old hardware
But I want to assemble it from 3 computers and use it
Best motherboard would be 4x serries (avoid INTEL DG41WV model, it has ram limit of 4GB):
INTEL DG41TY
No more 4x series, so next best thing -
GIGABYTE GA-P35-DS4
Best CPU
Q6600 CORE 2 QUAD
Two weaker cpus with highest L2 cache and highest base frequency:
E8400
E6750
Combine them, as you wish.
HEY
SkyNetRising
so i understand that this cpu Q6600 is the best from the list
and after him the E8400
but on the Strange that you rate the E6750 In third place
instead of E7500
Because the number of the series is higher
So how do you explain that?
And if you can please write me the best number one full board model that feet to the q6600 because I did not understand what a 4X is
and also the Second and third places
thanks again
but on the Strange that you rate the E6750 In third place instead of E7500
E6750 and E7500 are quite close.
E6750 has larger L2 cache (4mb vs 3mb).
But E7500 has higher base frequency (2.93Ghz vs 2.66Ghz).
By 4x series I meant - P/G 41,43,45 chipset boards. Board model names in previous post.
so i going to build from the list 3 computers
If I understood you correctly
the most strongest number 1 is :
Q6600 CORE 2 QUAD with GIGABYTE GA EP-43UD3L
number 2 is :
E8400 with INTEL DG41TY
number 3 is :
E6750 with GIGABYTE GA-P35-DS4
Yeah. Sure.
By the way I would love to understand what you meant
when you said that the chipset generations of the motherboard
What exactly does it do?
and what is better ?
E6750 with larger L2 cache (4mb ). ?
or the
E7500 with higher base frequency (2.93Ghz )
You are an angel!
Thanks again
what do you think about Intel DP35DP instead of the INTEL DG41TY
it can be better ?
and also about the DG41WV that have the G41 chipset ?
but memory are max to 4gb but still its a DDR3
8GB obviously is better than 4GB.
But this depends on usage scenario. If your system workload requires 4GB or smaller amount of ram, then max ram limit doesn't matter.
ok i will try the motherboad with the 8gb
By the way except for the two boards I mentioned are you sure there is no board from the list that has an advanced chipset like the X41 or something like that?
