[SOLVED] CPU block compatible with der8uer OC frame?
EK-Quantum Velocity D-RGB Nickel + Acetal +
der8uer OC frame
Like will pressure be enough? or do I need to use some custom screws
Doesn't the Der8aur frame come with adjustable mounting screws?
Personally, I think I'd prefer the TechN AM4 block since it's designed with the necessary offsets to optimize die cooling for Ryzen. At least the concept sounds good, and you can avoid the gimmickry of skewing the whole waterblock on top of the CPU.
der8uer OC frame
