CPU Change problem
Eonik
87
Hello. I have a laptop, and my current CPU is a Pentium t3200 2Ghz, i want to change it to a Core i3-3110M that i found really cheap.
My problem is: The i3 "fits" on my laptop?
Thanks
Different sockets, won't work. Even if the socket was the same, unless the manufacturers Bios supports it, it still might not work. If you want to upgrade, go to your laptop makers website and see what processors your model will accomodate.
Thanks 😉 Too bad.
