[SOLVED] CPU consumed by a process and it overheats
Jul 5, 2019
35
so when i start my pc the case is already heating much, and the videos are freezing sometimes(the sound goes normally) i checked task manager and i found that the task with the name service host: local system is making my cpu go to 91% usage, how can i solve this
thanks
(ITS A NOTEBOOK NOT A DESKTOP)
That's usually windows doing windows things. 99% of time you cannot do Removed about it.
It happens when you have slow storage or when its close to windows update. If virus reached that point, you can format you PC.
If storage is the issue (HDD as boot drive), defragment it, free some space, and that process will just finish its crap sooner.
If its update, then it will go away while breaking something else.
I would focus on overheating as a problem.
Reactions: haros_sg
so i checked, windows update is in the latest version of 8.1 i use win 8.1, my boot drive is clean litteraly y formatted it like 2 weeks ago and, since i formated it it is suposed to be clean of all type of virus i think
