[SOLVED] cpu cooler and cpu temperature issue
I don't think I would use that cooler with your CPU. First, it never says how much thermal energy it can handle. There should be some clue somewhere if it can handle 65W, 95W, 125W, 150W, etc. Your says nothing. Then, while it has a 120mm fan at the top, it's only 60mm tall. That's not a lot of material. Finally, the fan only moves 37CFM? Here is a random cooler from the "people also looked at" section.
https://www.amazon.ca/dp/B08M6D5XGQ
Notice in the title they show/claim that it will handle 125W CPUs. If you look at the product description/specs there is just a lot more info overall. I'm not saying the cooler I linked is a good one, but it's one I would at least consider. Yours I would have passed over as there are...
Notice in the title they show/claim that it will handle 125W CPUs. If you look at the product description/specs there is just a lot more info overall. I'm not saying the cooler I linked is a good one, but it's one I would at least consider. Yours I would have passed over as there are just too many unknowns. I would replace your cooler with a better one.
